My new deuce build "FIONA"
02smokemaker
32
moodus ct
Hello all,
I purchased a 1970 AM GENERAL M35A2 recently. This is going to be a build thread as I go.
It is in relatively good condition. It has 13k was rebuilt in 88. The PO did a craptastic paint job the wrong color shade and installed a 20k winch half way. It has a leaking radiator and partially working gauges. All the oil seals in the axles t case and trans are leaking.
I'm going to be fully redoing this in my own taste(which might change as I go).
I have already done the fdc bypass,aux brake master reservoir, spin on oil filter conversion, replaced some gauges, fixed the alternator. I ordered all new seals and a new seat. I also started fabbing up a hard top out of 1/8" plate and 1.5" square tubing.
Here are some pics!
Thanks for looking.
Chris
Karl kostman
880
Fargo ND
Chris your workmanship skills are commendable, I have a feeling this is going to be a very nice Deuce when your completed!
Karl
someoldmoose
Lancaster, PA
Fiona, what a fine name. Lyrical and distinguished. Looks like a terrific start you have made there. Is the hardtop designed to be removable (albeit with a crane)? I ask because I can't decide how I want to go with mine. Won't have a place to store a hardtop if I wanna eat bugs for a few days when the sun is shining.
02smokemaker
32
moodus ct
Thanks guys!
It will be removable! It won't be light but it will be built like the rest of the truck!!
02smokemaker
32
moodus ct
That's a wrap for fabbing! Now all the finish welding and paint!
The cab corners done
The front hold down and tie in for hat.
A good vantage point from my deck.
Next time you see it she will be painted!
02smokemaker
32
moodus ct
All done and mounted!!! (Except rear window)
Thanks for looking!
Tomorrow will be the new custom made radiator.......
tobyS
835
IN
Now there is a top that you can dance on....nice work. The overhang is a great addition too. I'll make a bet you don't remove it very often.
I have to ask...when you made cuts to make the long bend on the tube corners, did you come back and weld each one back together?
02smokemaker
32
moodus ct
So my radiator was progressively leaking worse on top of the outer frame rotting away. I refused to 8-900 bucks for a stocker. So I did some measurements and found that a 4 core aluminum radiator for a hemi dart was the closest I could find dimensionally and it's inlet and outlet are both on passenger side. It is also a downflow radiator like the duece. The inlets and outlets are too small but most places will modify off the shelf units for a fee. So I got the radiator for 200 and 100 to add 2" inlets and outlets!
Below are the pics of the build enjoy!
Took her for a hard ride today and she never went above 180°!
Thanks for looking!
rustystud
2,793
Woodinville, Washington
Thanks for looking!
Good job ! That's good to know about the Hemi Dart radiator. Where did you buy the radiator from? Summit ?
