my new engine
jdeoliveira74
wilmington nc
looks pretty clean... And it spins with a breaker bar feels smooth no grinding.
jdeoliveira74
wilmington nc
That is a GM date code. If there is a letter then 3 numbers, the letter is the month (skip I), next 2 are the day and the 3rd is the last number of the year. AMGeneral changed the date code on the blocks they cast. It will be 2 numbers then a space, then two more numbers followed by a letter. For example my block code is 10 04 J (Month, Day, Year). The years start with H for 2001, skip I then J for 2002, K for 03 and so on. The first "enhanced GM blocks" were supposedly cast starting on C-159. <--- Does this mean I got a navi star engine??? looking at my block its 12555506 and the other numbers are 12 12 H
ken
25
Houston Texas
Doesen't it say on the block right by the water pump on the passenger side? It should be cast 6.2 or 6.5 in 3/4 tall letters.
Warthog
231
OKC, OK
It is a AMGeneral GEP (General Engine Products) 6.5L engine. Build date of Dec 12 2001. The casting number is 506 whick is one of the better blocks.
You may want to do a compression check as the 6.5L weren't pulled without a reason.
I have one just like it with a blown head gasket.
Was there a green repair tag on the engine?
jdeoliveira74
wilmington nc
No green tag... the paperwork that came with the engine was blank too..It seems like it may have been a rebuild since the oil pan gasket and valve covers gaskets seem to be rtv as well as the water pump which looks brand new. Will check compression.. thanks
cedargrove
NC
That is the sought after GEP block. You have an excellent base to work with but like he said...It wasn't pulled for no reason. There is an issue somewhere. Now you have to figure out what it is.
I got one of these a few months ago. Got it home and could turn it with a breaker bar. Had oil pressure when I turned the pump with a drill. Fired off super easy without glows in the crate. Compression on 1 cylinder was off. Tore it down and found a couple of spun rod bearings. Crank journal fuxored. Bought a new crank, had the cylinders and main line honed, installed new cam bearings. It's on the stand waiting for me to re-assemble.
What did you give for it?
jdeoliveira74
wilmington nc
that is the sought after gep block. You have an excellent base to work with but like he said...it wasn't pulled for no reason. There is an issue somewhere. Now you have to figure out what it is.
I got one of these a few months ago. Got it home and could turn it with a breaker bar. Had oil pressure when i turned the pump with a drill. Fired off super easy without glows in the crate. Compression on 1 cylinder was off. Tore it down and found a couple of spun rod bearings. Crank journal fuxored. Bought a new crank, had the cylinders and main line honed, installed new cam bearings. It's on the stand waiting for me to re-assemble.
$250
11Echo
92
CT W. R.
This motor looks cleaner than yours and was junk.
When the pan was pulled it had pieces of #7 piston laying in it. There was a window into #7 water jacket also.
It's not a good idea to install any used motor without at least pulling the pan for a look inside. If it is fine, it just cost a pan gasket.
cedargrove
NC
Nice looking engine. Do these have any parts in common with civy chevy engines?
The block is the same. The heads have N/A precups. Piston squirts are disabled in all but 7 and 8. I have a N/A 6.2 in my 84 civi C10. I'm using my GEP block and heads, and transferring everything else from my 6.2. I'll use the ip from the military engine after swapping the 24v shut-off.
I'm not a MV guy. I'm a GM diesel guy. In the GM diesel community, these GEP blocks are highly sought after. It's basically impossible for us to buy a new bare GEP block.
jdeoliveira74
wilmington nc
I am super excited to that I got this engine... May tear into it this week if I have time. But most likely not till after christmas. I did notice some 2x on the block one on either side near the third injector... Also alot of blue marks all over the block
