ragedracer
- 2
- 18
- Phoenix, AZ
First, fired right up. Runs great. Checked all fluids - full and clean. Tires needed a little air, but looked good (looks aren't everything!). One of the tires was a uniroyal, while the rest including the spare were goodyear wranglers. Took it for a spin, ran to the gas station to fill it up with fresh diesel. Only took 7 gallons. Was pretty full. Checked fluids, tires, etc again. Everything looking good.
Well, I was wrong! I made it about 1/2 mile from the station. Then BANG!! The LR tire blew out. The mismatched uniroyal. See pic at the end. It shredded! Put on the new spare (brand new with an 08 date code!) and made it home great.
There were only 6 issues with it that I can find. Some I solved, need your help with a couple.
1. Blackout light didn't work. Pulled the cover off, found it to be a bad bulb. New bulb installed and works fine now.
2. Voltmeter in dash didn't work. Pulled bezel off, found out it was just unplugged.
3. Transmission output rear seal is leaking. Gonna have to replace that when I change tranny fluid and filter.
Now for the items I need help with...
4. Heater blower doesn't work, but it's because someone pulled the heater fuse. Is there anything I should watch for when I put a new fuse in? I did jump it and fan blew strong, but I didn't want to leave it for too long.
5. The shifter position indicator doesn't work. It seems to all be there, but I'm not sure how to hook it up. It seems like something might be broken off the dash. How does the clamp hook up to the column? I tried reading the -20, but I couldn't find it.
6. See pics below. This piece is just hanging behind the brake pedal. It looks like it should go somewhere! It has a little piece the slides back and forth. I can't figure out where it goes or what it does. Any ideas on this one? I tried to take a close-up and one showing where it is "naturally" hanging.
A couple last questions - the visor indicates 30w oil with an SF/CC designation. I can't find that at the store. The counter guy recommended 15w-40. Is that what I should use, or should I stick with straight 30w? Remember I live in AZ, so it never gets really cold here. I just want to make sure I get it right. This is my first diesel, so I don't know if there are specifics I need to know. And lastly, what are the small rectangular lights in the bumpers for? I can't seem to get them to light up.
Thanks!!
rr
Thanks!!
rr
