My "new" M923A2 is sitting in the driveway
Bluebeard
Truckee, CA
And I have no clue about the mechanics of this thing. I may have bitten off more than I can chew.... this thing is massive. I live in the Truckee area, near Lake Tahoe. So who do I call to do repairs? Right now, it appears the CTIS is not working as my rear left tire keeps going flat. When I turn on the CTIS all light flash, so I guess that means there is a leak possibly at that wheel seal. The largest socket I have is 3/4", so this thing is way out of my league- not to mention, I am not even sure I could lift the tire- even if I somehow managed to take it off, let alone figure out how to take the wheel apart. Who do I call? Do I take it to the local tire shop and watch them scratch their heads. I am sure mine is the first one of its kind in this town, as I have lived here for over 40 years and never seen anything like it driving on the road. Is there local mechanics in Reno that work on these things? Or do you just call your neighborhood diesel mechanic?
steelandcanvas
85
Southwestern Idaho
I would start by downloading the appropriate TM's for your M923, and get familiar with your beast. There are troubleshooting procedures for your CTIS. Your local mechanic unless he worked on these types of trucks in the military, won't have a clue when it comes to the CTIS. There are alot of good folks on here that will walk you through procedures you might not be familiar with. Good luck!
Bluebeard
Truckee, CA
We are building a "neighborhood" brush fire truck. When I get it farther along (water cannon mounted behind cab) I will send pics. Currently it has a 1600 gallon poly tank on it
with a bunch of 1.5 inch sprays, strategically placed all over the place. It is a "one man" fire department. A necessity when you live in an area surrounded by thousands of acres of bitterbrush
which burns like gasoline.
How much does a tire and wheel weigh? What do you have to do to get at the O ring that seals the air in the tire? Should I send it to the local tire shop, or
is this something an "under-equipped" backyard mechanic can take on?
1 Patriot-of-many
86
Zimmerman MN
Harbor freight has bigger socket sets ect reasonable. You'll need to invest in some tools. It's all Chinese made of course, I ended up bending a 3/4 or 1" socket wrench working on my deuce and a half changing torque rods and using a cheater bar. As to your CTIS, try holding down the run flat button for a couple seconds. See if it starts airing up. Yes the 5 flashing lights usually indicate a leak, having it in runflat mode you can usually find it and in addition it usually will air up the tires. These weigh about 500lb. I managed by myself to move one around, but soldier B is better. Don't set yourself on changing the big oring between the rims yet, you need to locate the leak, it could be as simple as tightening up an air connection. You can take the tire to any good diesel repair/tire shop if it turns out to be the big oring if you don't want to do it. I've taken a couple a couple from my deuce to my local car mechanic and had the big oring and the turret valve seal replaced. You'll have to order the parts at one of many vendors like ERIKS, the shop won't have a clue probably. Taking a printout of the pertinent TM to the shop is a good idea too. I've had a couple I just had to remove the shield and tighten a fitting on the hose.
Bluebeard
Truckee, CA
I'm not questioning your advice, but why would the "run flat" mode air up the tires? I would think it would let the air out. Either way I will try what you suggested to see if I can figure out where the leak is.
plode
South Jersey
Mechanics should be getting familiar with the systems, I see our new fire truck came with some sort of CTIS. It doesn't deflate the tires for different settings like on our trucks, but it has the ability to inflate them automatically if the pressure is low. A different system then what is on the military trucks, but same basic concept.
ke5eua
41
Baton Rouge (Central), LA
Run flat just dumps air into the system to keep the tire somewhat inflated during emergency needs. Really helpful when you need to air a completely flat tire.
Bluebeard
Truckee, CA
Duh.... no really..... I'm NOT as dumb as I look......
Makes sense to me.
Thanks for the clarification.
Bluebeard
Truckee, CA
Thanks for the uplifting thought. I just got done with hassling with Carnac on the VIN discussion forum, and after that whole episode, I was re-thinking whether I was loosing my mind or I was just a run-of-the-mill dumb*ss. It appeared that he thought I was talking gibberish to him. Some people are more difficult to communicate with than others. He was tough. But ultimately he pulled through and I appreciate it.
461
Sandyston, NJ
What a great combo this is. A guy that admits to knowing nothing about these trucks and after a few post thinks he knows enough to be a wise a**. Then to top it off he has one of the most unstable conversions of these trucks that can be prone to roll overs and other safety concerns. I think somebody didn't do thier research before buying this truck. Only advice I have is read the TM front to back and maybe take a CDL drivers course to familiarize yourself with big trucks and how they handle.
Bluebeard
Truckee, CA
Hold your horses here. I live on a flat table top dirt road; the truck -in its lifetime up here- will see less than 10 miles on it in the next ten years and yes, I have read all the posts about the ease of the way the roll over. This truck will spend most of its life parked next to my house. I get it that it is easy to roll over. It's not going to be driven more than a couple of miles an hour, and for a distance longer than a mile at a time on a straight, flat, dirt road.
What I don't understand here, is why does everyone think I am a wise-ass? Am I on another planet? I am just trying to get information, be as helpful as I can and trying to fit it. What is it about my posts that pisses everyone off?
Bluebeard
Truckee, CA
Wow, don't have to be an
You said in your first post you knew nothing about these trucks, and I was just explaining what the run flat mode does.
Oh, I get it.... you thought that I was calling you a dumb*ss....... .no.... I was calling myself the dumb guy.... in a self-deprecating way. I'm not here to pick fights with anyone. I guess I need to re-read my posts clearer, as everyone thinks I am attacking them. I was joking...saying I WAS THE DUMMY, not you..... Trust me, I appreciate all the info you guys give me. NEVER take any of my posts as a insult to YOU..... If it weren't for you guys, I'd be TOTALLY LOST. I appreciate everything you guy can do to help out.
461
Sandyston, NJ
Makes sense to me.
I think this was the post that got thee two of us going. Upon reading it a few times I see now that you were poking fun at yourself. When read quickly it seems like a wise a.. remark of like; Yea that was an easy assumption and I already new that.
Sorry for jumping so quick. But please make sure to atleast read the TM. These vehicles can be very useful and fun but also very dangerous if used unsafely at the same time.
ke5eua
41
Don't feel bad. Just remember, this is the internet, tone and convection can never be understood correctly in text.
Nah, I just wanted to throw a little humor in the mix with the pic.
These trucks are a best, and someone who has driven them a lot, along with fire trucks all I can say is be careful in whatever you do with them.
Bluebeard
Truckee, CA
The neighbors and I thought that the 5 ton would be BAD A** and I did a bunch of research on them and looked at the dozens and dozens of them on google images. So we felt pretty good about it. I read the webpage Roscommon Equipment Center and they pretty much said to keep the tank less than 1500 gallons and baffled. My neighbor wanted to get 1600 gallons because he said more water is better for watering the road. Some guys run 4000 gallon tanks on them, and that sounds like it would be scary. No, this thing will be parked mostly and maybe we may run it in a parade once we get it set up. For the most part, I am thinking about keeping maybe 500 gallons in it for running around (500 gallons and 20 gallons of foam can put most small fires down in a heartbeat) and if something big is headed our way, we will THEN FILL IT UP to hose down the houses, or fill it up to water the road occasionally.
Boy when that thing showed up, it was BIGGER than it looked in the pictures. It's been a fun project.
