My posts are getting smashed together ?
Mack Attack
Banned
152
Sauk/Prairie, WI
I type it all spaced, separated and neat, and select preview it shows it as I typed. Once I hit summit/post ect it removes all my spacing everything gets all jumbled up. This sentence was type with a line in between it and the few lines above once I post this it will end smashed up against the lines above it ! Why ? I have had my system checked all was ok'd on my end it started when the site was updated or what ever it was you did for maintenance. Help !
4,805
No issues here, or on multiple machines.
Pressing enter drops down to the next lines.
Spacing over from the left column, this line should move to the left tab justification tab. Will post this to confirm.
4,805
Yup everything works as it should. Going to try another post with spaces, but I'll preview it.
Next row with a space between.
Final row with a space.
Last row with a couple of spaces over. Should cause it to shift left.
4,805
Maybe you're trying to create columns of text? Which will not work.
Example:
Row 1 Row 2 Row 3
A B C
D E
F
G H I
Which I orginally typed up as:
PHP:
Row 1          Row 2          Row 3
A                B                 C
D                                   E
                  F
G                H                 I
Mack Attack
Banned
152
Sauk/Prairie, WI
Testing 1 space !Testing 2 spaces ! ! Testing 3 spaces ! ! ! First line I hit enter one, Second line I hit enter twice, and third time with and this should be only 1 line down ? ! Let's see Mack Attack
Mack Attack
Banned
152
Sauk/Prairie, WI
I got this "Testing 1 space !Testing 2 spaces ! ! Testing 3 spaces ! ! ! First line I hit enter one, Second line I hit enter twice, and third time with and this should be only 1 line down ? ! Let's see Mack Attack" Everything typed with a exclamation piont after it should of ended up below each other and it ended up as one long run on sentence. This I am typing 3 enters or 3 returns below the quoted material as though they were 2 separate paragraphs.Now this right now should appear as though I started a third paragraph, Are my posts showing up for you as explained ? Or as long run lines as I'm seeing ?
4,805
Going to be a local computer issue, the word wrap feature is global on the site. Are you using some tablet or something? Some other browser? Have another device to try from?
Mack Attack
Banned
152
Sauk/Prairie, WI
No I am NO trying to do columns I am basically busting up what I type as though they were separate paragraphs, instead of sentences. So each one of the lines should be. Triple spaced right now.If these show up as regular sentences its still goofing up.I am mobile, I am currently using a black berry cell phone. As I have for every post I have made on this site.For some reason since last sunday its started doing this.Maybe the system is jiving with my mobile system.
4,805
Sorry but I'm no help with blackberries. I've not touched one in 6 or 7 years now. Perhaps use the tapatalk application instead of the blackberry browser?
Mack Attack
Banned
152
Sauk/Prairie, WI
Ok well you did a great job and spent some time on it, I certainly appreciate the time and effort you invested. I guess I will have to try this app you mentioned. I just saw it got some crappy reviews so I never bothered with it.Thanks againMack Attack
Mack Attack
Banned
152
Sauk/Prairie, WI
Maybe I have no clue how to use it ? I get 4 icons one that looks like a binoculars, one that looks like a clock and one that looks like a gear, and one that looks like an "!" . . . Open to instructions ;-)
mark salanco
greenville sc
Here are the icons I have. The first one is for taking a photo, the next one is for selecting a photo form you photo library, the 3rd was is for twitter and the last icon is for settings.
I'm sure if your using a different platform such as android your icons will be different.
Mack Attack
Banned
152
Sauk/Prairie, WI
Looks Nothing like what I see on the app I just bought. I guess I will just have to get used to how jumbled up my posts look when using the regular browser . . . Or stop using this forum either way it is what it is ;-)
4,805
Yep its goofed up, I quit ! ! !
I mean no disrespect, but is using a computer not an option? Unfortunately the blackberry hold on the market is miniscule these days compared to iOS and Android in handheld devices. (And I honestly can be more of service with them) Unfortunately I don't even know anyone that has a blackberry that I could test with.
