My WMO Centrifuge Build
mmeridith
Apopka, FL
Still working on the piping, need to finalize a few hoses and then get the 240V electrical wired.
2 - 275 Gal IBC Totes, 1 for raw WMO and one for filtered
1 - 55 Gal drum for gravity feed to "fuge"
1- Northern Tools Oil Transfer Pump
1 - US FilterMaxx 3000G Centrifuge
misc pipe, valves, tubing, 5mic screen filter, fuel/water seperator & lumber
I used a 2" cross on the top bung of the drum with a double tapped 3/4" bushing in the end. The inside tap has a 2' long 3/4 pipe that extends into the drum and the top port on the 2" cross will act as a vent allowing the tank to "breath" and also is piped back to the raw tank as an overflow.
3dAngus
101
Perry, Ga.
Now that's a serious operation. Be sure to order extra fuel filters for your deuce.
It looks really cool. I would love to see it in operation and the finished product.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
I run 100% motor oil, filtered with my centrifuge. Change filters about once a year.
3dAngus
101
Perry, Ga.
Stretch,
Really? ONce a year. I could have never guessed.
How many miles or tanks would that be? Just curious.
3dAngus
101
Perry, Ga.
OK, I get it. I'm guessing my estimate for a dozen or so fuel filters is exaggerated. I'll remove the suggestion.
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
Granted, it depends on how long they are run, and how dirty the oil is, but a "fudge" filters better than filters, if that makes any sense.
Beyond Biodiesel
37
Prescott, AZ
Nice WMO processing setup. The advantage that a centrifuge has over filtering WMO, is most of the particles in WMO are sub-micron colloid free carbon and ash. Filters will only get the >1-micron big chunks out. I use both filters and a centrifuge to process my waste oils into diesel fuel. I start with coarse screens, then blend, then settle, then fine screens, then filters, then centrifuge. It means I only need to pass my fuel through the fine screens, filters, and centrifuge once.
Stretch44875
Super Jr. Moderator
30
Tiro, Ohio
I was doing 3-5000 a year, maybe 2000 now? Could probably go two years on a set of filters.
77REBELBOWTIE
SYLVESTER, GA
I'm looking to get into the milsurp vehicles very soon, in fact I have my eyes on one at the moment:-D. Do you have to have a centrifuge or can you just run it through multiple filters? Can you give me any places to get good information? Contrary to popular belief, not everything on the internet is true.
My idea is to install a 250gallon tote onto a trailer for oil recovery. I will also purchase a milsurp fuel wagon on which I plan to install my filtering setup. Not being a prepper, but just in case things go south, it will already be portable. I will also run a length of aluminum or stainless tubing from the rear of the truck to the fuel tanks. It will have a filler cap on the rear and be plumbed into the tank. This will eleiminate having to have a long length of hose to reach from the wagon to the tank. What do you guys think?
Beyond Biodiesel
37
Prescott, AZ
There is a lot of information available on this section fo the forum, so read through some of the threads. I find WMO has a lot of sub-micron particles, so just filtering is not enough. So, a centrifuge can help remove most of the sub-micron particles. However, I have been running waste oil/gasoline blends on my 6.2L for almost 7 years. Even filtering WMO-gasoline blends down to 1-micron, then centrifuging it still does not clean up the blend enough for it to run on my 6.2L without coking its injectors. I do not know how it will run on my deuce, but I do not want to ruin its engine to find out. I have plenty of WVO, and it runs fine on my 6.2, so I see no reason why it will not run fine on my deuce.
