kochevnik
- 1
- 18
- Colville WA
Can anyone tell me the physical dimensions of a 400 gallon water buffalo tank (from the M107a1 or the M149) ? I am looking to find diameter and height of the tanks. From the fotos it looks like the tank is kind of 'squashed' in the vertical dimension.
My idea for this is to use it as a long distance secondary fuel tank / WMO collection tank (obviously not at the same time ) and I want to mount it on the back of a M52A2 (after removing the 5th wheel and installing a flatbed/pipeline bed). I'm trying to see if this would fit crosswise on the truck kind of up behind the cab. I would take the tank off the water buffalo trailer, make some mounts to fit and set it behind the cab on the bed.
Anyone can measure the tank or point me to a tech manual that would have this info. Anyone know also how difficult it would be to detach the tank from the trailer (without wrecking it) ?
I know there are fuel trailers as well, but I couldnt find an M code for them ? Any of these 200,300,or 400 gallons ?
