Name that part!
Jusjofok
Wichita, KS
Quiz time!
Can someone tell me what this part does or is supposed to do? It appears to be a hydraulic cylinder and was mounted to the floorboard below the clutch arm. The slotted yoke went around the clutch arm (rh side of the clutch pedal torque tube) and traveled with the clutch rod. The arm on the clutch torque tube isn't the normal arm with a square hole and a round hole for the pull rod, it is cast with a slot for the clutch rod (it is shown in picture 2, i am not using the cylinder part but I am using the arm so the washers are there to take up the slack). The clutch rod isn't the normal 5/16" rod with a 180 degree hook on each end but a welded assembly that attaches to the clutch torque tube (next to the steering gear in the wheel well) via stud and nut. There were no hoses or lines attached to this thing when I got it. If you blow into the ports with compressed air it moves like a cylinder. The problem with this thing is that the clutch rod blocks the hole for the fuel line (see pic 3), it was installed but was rubbing and binding and has actually worn a hole in the line. This is not something someone has built and installed, everything about it is professional, the clutch rod even has radiused gussets. Has anyone ever seen anything like this before? I have looked through all the manuals I have and haven't found any references to it at all. The only thing I can think of would be a hill holder of some kind but that seems far fetched for a military jeep.
Jusjofok
Wichita, KS
It could be. I looked for other features on the vehicle to suggest other attachments but didn't find anything other than some odd brackets on the back floorboard. I will get a picture and post it.
Jusjofok
Wichita, KS
I considered it might be a clutch master setup but why the fancy clutch rod then? And I didn't think the M151 series ever came with a hydraulic clutch.
