Need 250 cummins injector pump
jcappeljr
27
Delta, PA.
I think the IP went out of my M817 ,it wont even try to start when you put the fuel line coming from the fuel filter into a can of fuel.I even tried screwing in the fuel selinoid screw.
steelsoldiers
3,971
Charleston, WV
If you can't find one, then you can always have yours rebuilt. I had one redone for around $250. Any reputable IP shop should be able to handle it.
ncduece
wilmington nc
try using a outboard motor primer bulb to prime it with, there is an air bleed screw up by the air intake preheater crack that then prime it with the bulb. even after that its a pita to get it started, i have to use ether to get it to start after a lot of air gets into it,
