fal_shooter
- 0
- 0
- Post Falls, ID
Looking for a fuel pump push rod. It's a discontinued part. Anyone know of a replacement part number or source? The one I have is broken in half.
First off, I love building FALs. Maybe block it off and get an electric lift pump? Hope I don't take too much heat for that suggestion.Looking for a fuel pump push rod. It's a discontinued part. Anyone know of a replacement part number or source? The one I have is broken in half.
Thanks cucvrusI have the fuel pump push rod. Of course I do. I would like 2 expired Idaho license plates for it. Nice clean ones please. No need for another hacked up wiring. The OEM system works well. It lasted 33+ years. That's pretty good. Let me know. I will mail it out. Any other smalls you need?
I'm no expert but I think on some applications FP pushrods are hardened, at least on the ends. Maybe someone else knows. Hopefully it holds up fine for you.The shop could not find the rod so we had one machined at a local shop. I just picked it up and it seems to start OK again.
Shouldn't need a new pump for that, try GM wiper motor controller, part number 15598496. Pictures here. Slower speeds from the original motor may be just dirty electrical connections or mechanical linkages in need of attention, aka cleaned and lubed.... If it keeps running, my next project is to put in a new washer motor. I replaced the steering column with a tilt and it has the intermittent wiper function so I want to get a new wiper motor to take advantage of that function. I get tired of the two speed slow and slower original motor...
