Need a Guiding Light
Lugnuts
266
Myakka City, FL
Attempted a search on Hydraulic Tanks that fit the air pump for the Cab Lift, etc, and turned up nothing appropriate. I am looking for replacement tanks. Prefererably not the plastic ones but aluminum. They don't crack or the helicoils don't get ripped out somehow misteriously. Any guidance is wonderful.
Thank you
Lugnuts
266
Myakka City, FL
So I went to the parts manual and did find the part number of both gasket and reservoir and now I am asking for different information. Where can I buy reasonably priced tanks. Aluminum used? I feel I just got raped window shopping!!!
Lugnuts
266
Myakka City, FL
Thank you, guys. I looked at the tank and no picture. Do you know by chance if that tank is aluminum or the plastic? Didn't know if you had personal experience buying it?
Lugnuts
266
Myakka City, FL
I bought an Omega tank/ Aluminum/ Very little modification required i.e. a partial molding trim that does not weaken the tank/ Part #A57-6-1601-107 for the tank and the gasket is A57-3-9901-101/ The plate on the pump were it screws to the tank those holes will need to be drill out to accommodate the gasket/ Mounting holes are the same/ The total cost on those were $130/ By the way the tank was painted red so I am sure that will also need modification!!!
