need a injection pump?
84cucv1ton
New Jersey
m1009 with 26k. starts and runs. seems to me that once i get going and need more throttle, for like a hill. just seems to fall on its face. so im thinking injection pump?
what do you think? anyway to test it? thanks
jag7720
Kansas City, MO
mine does that too... especially when on diesel... when on WVO it acts normal.
I asked this question and was told to increase the fuel supply. I plan on doing it.. just haven't had time.
Banks Turbo has an install manual for their turbo that tells you how to do this.
Wolf.Dose
9
Boehl-Iggelheim, Germany
To me sounds like a clogged fuel filter. Or the main fuel pump does not work propperly.
Due to the simple designe of the injection pump this device works or works not, as long as the filling fuel pressure is at the minimum required (more than 3 PSI). Other cause might be, that the return valve does not close propperly which means the pressure in the pump is not building up in the intended way. However, this creates usually also starting problems (3 degree advance is not given).
Are the injectors set at the propper opening pressure of 125 bar plus 5. Else the firing is poor, starting also (reason: incorrect injection timing).
Wolf from Germany
