Need a name on this part
Nick m1009
Glendale,AZ
hj.jpgget-attachment.aspx.jpgcan find a name if some one can find out what this is, (what I was told) 60psi going into it but nothing out, it has two hose on it and that is all that I know
cucv1833
Lake Charles, LA
Part#-14057219 (Vacuum Valve Regulator) for transmision set points. you can do a advance search for more info and how to set. A new one cost around $150. I think 60 psi is incorrect. The TM manual talks about 8 in. of vacuum
1,174
Remember, the -20P and -34P TMs are simply exploded views of all the parts, with part numbers and names.
Nick m1009
Glendale,AZ
well well like always you guys are quick with the answer now to hit the field with the knowledge at hand, I will respond with the outcome hopefully if it is the correct part/fix thank you guys and anyone with a responds still would be nice just encase these are the incorrect parts or in case of it being another name for it, Thanks
cucv1833
Lake Charles, LA
I looked at your picture then looked in the TM-34P and thats the correct part # and name. I also changed one out before and ordered a new one from the part# doing a google search. Whats is the problem with yours? I bought a new one $150 and it wasnt the problem at all. My problem was a .25 cent vacuum hose.
Heres the site for the Manual.
http://www.jatonkam35s.com/jatonkaCUCV-TMdownloadpage.htm
blackhueys
-9
mn
Just got one myself of fleabay if that helps my truck actually shifts right now change all of your vacuum lines first cheaper way to go if that does not work then I changed the switch.
cucv1833
Lake Charles, LA
well it shifts really hard 1-2 gear I know that i have 60 psi going into the vacuum and nothing out
Check your vacuum lines for damage and dry rotting and let us know whats up.
Mine did the same thing and i changed out the 3" Vacuum line on the transmission vacuum modulater and i was good to go again.
