Need a wiring diagram for 1963 m-37
Jimma
Hartwell, GA
We have replaced many electrical items on the 1963 m-37 including batteries, voltage regulator, generator, turn signal control box, turn signal switch etc. Everything else now works but the turn signals dont seem to be working even with the new parts. I had a wiring diagram but it must be from an older version as it does not match up on everything. Does anyone have a good wiring diagram for a later model m-37? Any suggestions as to wiring the turn signals to get power would be great as well. Thanks
Jimma
Hartwell, GA
Does anyone know if the older m-37's had a different wiring diagram or routing than the later models? I have a 1963 and am having difficulty with turn signals. We have installed a turn signal switch and a control box, a new voltage regulator and a new generator. Everyting is working but the turn signals. Any adivice?
AN/GRC-46
SW PA 15102
If you have a 1963 then you have an M37B1 and the wiring is indeed different from the earlier M37. I can tell you that much but unfortunately I no longer have the reference books to help you out. Someone here will come up with the info you need.
