ETN550
- 9
- 0
- Knoxville, TN
Just want some of you experts to chime in and let me know if I'm on the right track and should be repairing vs replacing the A1V1 main voltage regulator in the 016E. From the tag on the regulator it does say used on 5kw and 10kw so if common all of you 002 and 003 experts can help too.
This regulator was in a 701A and I swapped it out with a good one from an 016E and now need to fix it or replace it to make the 016E useable.
What it does is after about 5 to 10 minutes of running any load, the voltage drops off until it gets to about 106vac maxed out in the 120 single phase mode. It just slowly starts decreasing and keep going seemingly regardless of heavy or light load.
After it cools off and I restart it will max out at 122 - 125 and then start back down again. This was repeated about 4 times so I became convinced it was being consistent.
I removed the A1V1 regulator and slid the board out and left it hanging by the wires. I only found 2 capacitors on the board.
The appearance of all of the components looks great. No signs of heat or burn marks.
Is there anything else to replace and is the cost of doing a blind replacemnt worth the chance it will solve it?
Thanks for comments and advice.
Doug
Doug
