Need Advise on a Mep 005A Generator
Old Man
Wapakoneta, Ohio
Purchased a Mep005A generator that only has 45 hours on it but has obviously not been ran in many years. Had to clean the fuel tank out, replace the primary fuel pump and clean the strainer basket in the other one. Had to clean the fuel filter cans and install new filters. I now have clean fuel to the injection pump but it will not start. Cracked the injector lines loose at the injectors but no fuel there. Bone dry. Is there anything I can check or try short of replacing the pump? With only 45 hours shouldn't be anything worn out yet. Appreciate any help.
