- 4,640
- 28
- 38
- Cambridge, Ohio
Hello,
I started to rip into my brakes today on the new deuce. I figured I would do a thorough inspection before I tried to adjust and bleed to brakes. I pulled off the drivers side front drum and inspected everything, so far so good.
I read on the forunm, when re-installing the drum and hub, to put some RTV in the keyway on the spindle to seal it. OK, I have no problem with that...IS THERE SUPPOSED TO BE A KEY IN IT? When I took the hub off, there was no key in the keyway? Is it supposed to be there or not. I don't have enough cribing to prop up the truck and pull the other side to look, and the TM I have doesn't have a drawing of the front hubs, so i thought I would ask the experts?
Please, someone who has done this before, respond so I can get it back together and move on to the next wheel. Thanks
