need clutch and preasure plate.
zb39
PA
Any tips for changing these out and or where to get them?? I can't seem to get them adjusted right. Seems like a fork on the pplate might be bent or broke?? It will not completly disengage. Doesn't seem to slip, just won't let me disengage.
98hd
Reedsburg, WI / Trenary, MI
Equipmentparts or something like that has cheap disks (check their ebay store).
OD iron has the pressure plate, but it's expensive. I think I got the last one from saturn.
For me the biggest pain was torquing the flywheel to spec. and getting the trans re-installed. Even with an alignment tool it was a PITA go get the input to slide in.
73m819
319
gainesville, ga.
i got all the 5t clutch parts from white owl, doing my clutch was not to bad, rigged up a pipe though the back and front windows, two come-a-longs, removed the front and trans to xcase shafts, unbolted everything, slid it back, dropped the clutch, ect. took me about 4 hours to pull it and about 6 hours to put it all back, went to Tocoa the next morning. the trick is to THINK IT ALL out before you touch a bolt
