Need for brake upgrade after drive ratio change for more speed?
csoledade
Nederland, CO
Hello,
I was trying to search (with no real luck) for threads that might have information on the need to upgrade brakes after the drive ratio has been upgraded to enable faster speeds.
70MPH would be nice for the occasional HWY segment, but I want to make sure the LMTV can stop and turn at those speeds.
Any suggestions on search terms to use to find this information? Anyone with experience want to provide their insights?
Thank you.
Overdrive
96
Wentzville, Missouri
I don't have search terms but I know for a fact that Meritor makes disk brake versions of our LMTV axles and I have seen them on an advertising brochure. I would be a swap to disks would improve a number of brake functions.... One of my holy grail mods in the distant future.
OD
NDT
6,486
Camp Wood/LC, TX
This topic has not been covered here (yet). The brakes are sized for 5000 lb payload, so running empty should be no prob to haul down from an extra 15 mph.
tburk49760
10
spokane washington
Having done the regear and quite happy with it, I can tell you that without some added power, cruising at 70 on anything other than flat ground with little to no load, jus isn't gonna happen very often if ever... Cruising at 60-65 more realistic, even loaded fairly heavy. Turning and braking aren't a problem. I can hit 74 but just barely and that's balls out...
csoledade
Nederland, CO
Thank you very much for the realistic driving report. I appreciate it. Do you have one of the trucks with a 3116 engine?
I read that it is much easier to tune horsepower and torque on the later C7 engines in the M1078A1 trucks with just an electronic remap. I also read that tuning the 3116 require a turbo replacement or marine injectors. Another thread mentioned that the tuning does not really affect the end cruising speed, just the ability to work up to that speed with much less effort. The engine upgrades make the truck more responsive not necessarily faster.
Do you know if the 3126 engine a middle upgrade step between the 3116 and C7 engines?
Thanks!
csoledade
Nederland, CO
OD
Thank you. I may be adding that to my holy grail list as well! Any info you have on part identification or part numbers for the Meritor disc brake/axle upgrade?
scottmandu
36
Texas
When top speed is gearing limited more power means you can get there quicker or maintain higher speed on inclines. The stock turbo is ridiculously small on the hot side. I wouldn't go higher than 290 on the stock turbo egt's get out of hand quickly. I've got an upgraded S300 on my rig, but I haven't had a chance to fully test it as the A/C install isn't complete.
