need front wheel bearing and boots for m35a3
Coalman
Paxinos Pa
Please don't say use the search I did and did not find anything I need to replace the front drivers side wheel bearing on my a3 . I was out for a ride today and heard a squeaking sound with turned into a grinding sound and then started to smoke out of the front wheel I did get to baby it home . So my question is can I buy a kit with bearings races and boot or is it best to just buy the parts seperate ?( where is the best place to purchase them ) I plan on changing the boots right away also, I am going to fix the bad side and also take the other side apart to inspect and grease also Thanks for the help
4,695
I'm afraid you're going to be in a bit of shock when it comes to the cost of bearings...
willy
Martinez, CA 94553
front BRG
Erik has the Brg at a cost off 935.00 each
You are almost cheaper off buy the convertion from A3 to A2,
I believe eastren Parts
For $675 for 1 axle both sides.
You will get 2 new spindles, 2 grease seals,4 set off Brg (not timken) instruction good deal but you will loose your CTIS.
Willy:wink:
Or you can get the rear convertion (cheaper) and use the brg op front you would loose the CTIS for that wheel
dmetalmiki
2,027
London England
what the heck does this translate to please? (we have had moderator comments about avoiding vague Mobile phone speak, and keeping is plain simple and easy to read in full)
<Or you can get the rear convertion (cheaper) and use the brg op front you would loose the CTIS for that wheel > brg op??? my nephew asked me what this refers to..I told him I have NO idea.
4,695
I am still looking I checked all over and found a few but very expensive any help guys Thanks Kevin
Unfortunately that's your options, very very expensive or just very expensive when it comes to replacement bearings.
Pajaro
NM
Great advice. Going through the same thing. Inner bearings are 450 each! THX!
Willy:wink:
Pajaro
NM
Thanks country, I appreciate the links and info. This WILL be the route I am taking. CTIS did not work anyway...
