need generator and compressor info
rizzo
Port Huron, MI
is the [FONT=Verdana,Arial,Helvetica]MEP 0016D a 3 phase generator? is there a small diesel generator that is not a 3 phase?
I am also looking at a
[/FONT][FONT=Verdana,Arial,Helvetica]MC 2A compressor. just gonna use it for air tools and tires and things. does it have a tank? do they work good? anything I should know about them?
thanks
[/FONT]
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
I can't help out on the compressor, but I believe that the MEP-016D generators, most if not all are diesel engine sets. They are 3 Phase, but have a switch for 120/240 volt single phase operation and 120 volt only single phase operation.
Isaac-1
50
SW, Louisiana
The MEP-016A-D (A-E?) series all use the same generator end, the voltage selections are a bit unusual, they include 120V only single phase, 240 V only single phase (no 120/240 single phase though, but it can be created by adding a single jumper wire when 240V only is selected on the voltage reconnection switch), also 120/208 Wye 3 phase, and an odd 120V only 3 phase mode. Internally this unit is a 6 lead reconnectable generator.
Ike
