Need help figuring out what year my deuce is.
Delby
price,UT.
Hi everyone
I'm new to the place and love everything on here.I bought a duece and a half but it didn't come with a title.One tag on the dash say's that it was overhauled 7-86 but I can't find an actual year of mfg. on it.Any help would be great.I'v also got the stock # and serial # and the mfr.serial #.
FreightTrain
Banned
2,730
13
Gadsden,Al
RE: Need help figuring out what year my duece is.
ummm,if the frame is uncut that is a Long wheel base deuce.M36A2......we need the numbers off the data plate to figure out year.Can you take a photo of the plates on the passenger side and type up the numbers stamped on it?
DDoyle
80
West Tennessee
Based on the mfr serial number you posted, your truck was built as a M46A2 chassis, not a cargo truck. I have darn little data on this type chassis, however, the registration number 4B9775 does not "look" right (registration numbers from this range should be from the very early 1960s - AM General didn't exist until 1971) The prefix (03) of the serial number stamped on the data plate dates for 1968-1969, and in that time frame the registration numbers SHOULD have been eight digits. And the data plate stamping doesn't "look" right either.
Info from the data plates is OK as a secondary source, much better would be the numbers embossed in the frame, probably near the driver's side shock mount.
Locate the frame number and post it, and you'll get better information. I presume the truck came through a dealer?
Best wishes,
David Doyle
Delby
price,UT.
Awesome Thank's I got em frame numbers are 033411882 it also has the air shift transfer case in it. also I noticed that the tag said M45 on it does that make any difference or is it still considered a M35. Thanks again
DDoyle
80
West Tennessee
Re: RE: Need help figuring out what year my duece is.
Your truck (and the M35, and a host of other 6x6s) SHOULD be considered in G-742 - but since sometime in the 1960s few people have used such designations, resulting in a great deal of confusion.
Your truck is a M45A2 - and should be referred to and considered as such, especially when ordering driveline components.
Based on the frame numbers - your truck was built by Kaiser-Jeep - I suspect in 1968. Medlog MAY be able to pin this down for you. Are there any numbers stenciled on the inside of the door, or on the underside of the hood? These would help.
The ID tags riveted to the axles and transfer case are liikely date coded, as are the steel rims - these would help as well.
Best wishes,
David Doyle
CARNAC
The Envelope Please.
649
Corpus Christi, TX
This what the registration number brought up. There serial number doesn't bring up anything.
Organization: TOOELE ARMY DEPOT
Nomenclature:WTR PURIF EQUIP SET Model:TRK MTD NSN:4610002026925
Serial Number:1500313 Registration Number:4B9775 Year of Mfg:1961
Manufacturer:91340
Acording to the database it was rebuilt in Toole in the 1985 (your tag says 1986 and that may have been when they completed the rebuild and stamped the tag). Truck was coded out of service in Apr 1987 by Camp Robins, Arkansas Army National Guard. Now that is our tax dollars at work.
Hope that helps
Delby
price,UT.
Awesome guy's Thank's a mil. There is a triangle tag riveted right below the driver's seat on the steel plate that come's up from the floor,not sure what ya call it though.I don't know if that would help or not.I'll go and look under the hood and stuff.
DDoyle
80
West Tennessee
the triangular tag is stamped with a MWO (Modification Work Order) number- probably saying seat belts were installed.
Boy, I'd sure like to have the complete original bed off this truck....
HOWEVER, this brings up an interesting theoritical discussion - the registration number was assigned to the complete "assembly" - a 3000 GPH ERLTOR, which was built in 1961 (which corresponds to the registration number style). As I understand this (including my experience buying one - and seeing others sold), for accountability purposes to the army this is not a "truck" it is a water purification unit - and this is reflected by its FSC.
In the instance of this vehicle - the chassis in question with certainity was NOT the one underneath the now missing bed when the bed (ERLATOR) was built, and the registration number assigned. Rather, the chassis is somewhat newer (I am still thinking 1968). The "truck" carries the ERDLATOR registration number (which makes sense for accountability) - BUT, in all probability at one time the chassis had its own registration number (since it was built as a cab and chassis, as we know from the serial number) - and when the bed and chassis were joined, the chassis registration number would have been replaced by the bed registration number, and the chassis would have "ceased to exist".
How would this be handled on the property books?
Thanks Delby for posing this question, which gave us this information - which helps us all unlock the story of these trucks.
Ever digging,
David Doyle
Delby
price,UT.
OK here's what I found. Front axle has serial # 0041167 and ( look's like a date to me ) 11 4 68 stamped on the housing.
Front rear axle has model # C240 PHX3 serial # 0018558 and 7 22 71 stamped on the housing.
Rear rear axle didn't have the tag it was missing but had 11 5 68 stamped on the housing.
So I don't know what I've got. I really appreciate all the help from you guy's. Thank's Delbert
DDoyle
80
West Tennessee
The chassis was assembled in November-December 1968, or early 1969.
Delby
price,UT.
Cool Thanks So should I try to get a title and tag it as a 68 or what would you do.
CARNAC
649
Corpus Christi, TX
The truck lost it's identity when it had the water purification system put on it because it became a system.
I doubt we will be able to pull this from the database at this point. Only chance would be to find a different registration number that happens to show up.
Delby
price,UT.
OK Thank's So what do I need to do from here so that I can try to get a title for it.Could I just tell them the serial # on the frame or should I try to get a new serial # from the DMV.
ida34
33
Dexter, MI
Use the serial number on the frame. I would also replace the dash data plate and make it match the frame. It is illegal to remove or alter vin plates but I don't know if your local judge would consider this a vin plate or not. The military did it but they are kind of exempt from prosecution for it. The big point is the data plate is too easy to remove and replace. Some officers will want to see a more permanent vin and the frame number would do. A state issued vin is an option but it is a lot of hassle.
steelandcanvas
85
Southwestern Idaho
I agree with ida34, the VIN number stamped in the frame would be the way to go.
Delby
price,UT.
RE: Re: RE: Need help figuring out what year my duece is.
You guy's are awesome. Thank you so much for all the help ( lord know's I need it ). So for starters what year should I tell them it is.
A 1968 and I guess the make and model would be AM General M45A2. Also will i need to get another data plate to put back on it and if so where can I get one ? Once again thanks for everyone's help on this. Delbert
CARNAC
649
Corpus Christi, TX
Just for completeness on this, here are all the 000771623's still able to be looked up. All others have been purged.
FSC NIIN MODEL SN REGNO YR MFG
2320 000771623  M45A2 W/W 22520051  4S01569  1972
2320 000771623  M45A2 W/W 22520070  4R97569  1969
2320 000771623  M45A2 W/W 22520072  4S02369  1969
2320 000771623  M45A2 W/W 33410007  4A26468
2320 000771623  M45A2 W/W 33410016  4A27368
2320 000771623  M45A2 W/W 33410018  4A27568
2320 000771623  M45A2 W/W 33410021  4A27868
2320 000771623  M45A2 W/W 33410023  4A28068
2320 000771623  M45A2 W/W 33410025  4A28268
2320 000771623  M45A2 W/W 33410026  4A28368
2320 000771623  M45A2 W/W 33410037  4A29468
2320 000771623  M45A2 W/W 33410046  4A30368
2320 000771623  M45A2 W/W 33410060  4H01469
2320 000771623  M45A2 W/W 33410061  4H01569
2320 000771623  M45A2 W/W 33410062  4H01669
2320 000771623  M45A2 W/W 33410078  4J59769
2320 000771623  M45A2 W/W 33410085  4J60369  1972
2320 000771623  M45A2 W/W 33410123  4K21369
2320 000771623  M45A2 W/W 33410389  4C59370  1972
2320 000771623  M45A2 W/W 3829651  4A26268
2320 000771623  M45A2 W/W 43410005  4A04669
2320 000771623  M45A2 W/W 4341001  4A00269
2320 000771623  M45A2 W/W 43410013  4A05469
2320 000771623  M45A2 W/W 43410016  4A05769
2320 000771623  M45A2 W/W 43410019  4A06069
2320 000771623  M45A2 W/W 43410020  4A06169
2320 000771623  M45A2 W/W 43410021  4A06269
2320 000771623  M45A2 W/W 43410022  4A06369
2320 000771623  M45A2 W/W 43410031  4A07269
2320 000771623  M45A2 W/W 43410033  4A07469
2320 000771623  M45A2 W/W 43410039  4A08069
2320 000771623  M45A2 W/W 48410003  4A04469
2320 000771623  M45A2 W/W 53410033  4G48870  1969
2320 000771623  M45A2 W/W 53410304  NK01W7  1969
2320 000771623  M45A2 W/W 53410326  NK01XH  1972
2320 000771623  M45A2 W/W 53410343  NK0204
2320 000771623  M45A2 W/W 53410347  NK020Q  1969
2320 000771623  M45A2 W/W 53410374  NK024P  1969
2320 000771623  M45A2 W/W 53410385  NK026A
2320 000771623  M45A2 W/W 53410395  NK027S  1972
2320 000771623  M45A2 W/W 53410434  NK02DH  1972
2320 000771623  M45A2 W/W 53410440  NK02ED  1972
2320 000771623  M45A2 W/W 53410457  NK02GW  1969
2320 000771623  M45A2 W/W 53410458  NK02H1
2320 000771623  M45A2 W/W 53410478  NK02KZ
2320 000771623  M45A2 W/W 53410484  NK02LV  1969
2320 000771623  M45A2 W/W 53410487  NK02MA
2320 000771623  M45A2 W/W 53410498  NK02UD  1972
2320 000771623  M45A2 W/W 53410500  NK02UG  1978
2320 000771623  M45A2 W/W 53410511  NK02X2  1978
2320 000771623  M45A2 W/W 53410512  NK02X4  1978
2320 000771623  M45A2 W/W 53410513  NK02X5  1972
2320 000771623  M45A2 W/W 53410514  NK02XB  1972
2320 000771623  M45A2 W/W 53410520  NK039G  1978
2320 000771623  M45A2 W/W 53410522  NK03B8  1978
2320 000771623  M45A2 W/W 53410525  NK03DW  1978
2320 000771623  M45A2 W/W 53410526  NK03ES  1972
2320 000771623  M45A2 W/W 53410532  NK03K6  1978
2320 000771623  M45A2 W/W 53410568  NK03VS  1978
2320 000771623  M45A2 W/W 53410577  NK03YE  1978
2320 000771623  M45A2 W/W 54010339  NK03BB  1972
2320 000771623  M45A2 W/W 54012361  NK05P3  1972
2320 000771623  M45A2 W/W 54012647  NK05XH  1972
2320 000771623  M45A2 W/W 54410001  4M26270
2320 000771623  M45A2 W/W 54410039  NK04W7  1972
2320 000771623  M45A2 W/W 54410051  NK04Z3  1972
2320 000771623  M45A2 W/W 54410053  NK04ZJ  1972
2320 000771623  M45A2 W/W 54410056  NK050A  1972
2320 000771623  M45A2 W/W 54410059  NK0510  1972
2320 000771623  M45A2 W/W 54410074  NK057A  1974
2320 000771623  M45A2 W/W 54410075  NK057R  1972
2320 000771623  M45A2 W/W 54410080  NK059Y  1972
2320 000771623  M45A2 W/W 54410087  NK05D0  1972
2320 000771623  M45A2 W/W 64410051  NK075C  1974
2320 000771623  M45A2 W/W 64410059  NK075L  1974
2320 000771623  M45A2 W/W 64410082  NK0BFH  1977
2320 000771623  M45A2 W/W 64410085  NK09PL  1975
2320 000771623  M45A2 W/W 64410089  NK09PQ  1975
2320 000771623  M45A2 W/W 64410090  NK09PS  1975
2320 000771623  M45A2 W/W 64410093  NK09PV  1975
2320 000771623  M45A2 W/W 64410106  NK09QB  1972
2320 000771623  M45A2 W/W 64410110  NK09QG  1975
2320 000771623  M45A2 W/W 64410116  NK09QP  1975
2320 000771623  M45A2 W/W 64410123  NK09QX  1975
2320 000771623  M45A2 W/W 964155  4M26870
2320 000771623  M45A2 W/W J65623  4A06569
1,808
Since its a 68 and AM General hadn't been formed yet, I'd not list it as an AM General. The only manufacturer making deuces in 68 was Kaiser Jeep. List it as a Kaiser Jeep and you will be accurate.
m16ty
218
Dickson,TN
Re: RE: Re: RE: Need help figuring out what year my duece is
I had a truck that came with a title and it had listed "1976 Kaiser Jeep". As everyone knows it would have been a AM General in 1976. The truck was acually a 1953 Reo (I think) but that's a whole another can of worms.
I've also seen several trucks advertised that listed the engine date as the truck year by people who don't know any different. I went and looked at a truck that said "1986 M35A2". When I got there it wasn't. The engine was made in '86 but the truck was much older.
