Need help finding acceptable parts
Herls
24
Massachusetts
Need a new steering box and power steering pump for an 85 M1009. I have the TM and have found the CAGEC numbers but I'm having trouble finding which modern versions of the parts are acceptable for use. Which brands / companies for steering boxes and power steering pumps are acceptable to use and what are their part numbers?
Thank you!
WWRD99
1,712
York Pa
Thank you!
I can't help much with a steering box since I rebuild mine or adjust them tight again. I know there's some good builders out there that make them for off road guys that should be put together right. I'd hate to box store one and end up with cheap parts inside. They're a good bit to change with the pitman arm to press off. I do buy pumps though from parts stores. I do swap the pressure valve and spring out of the original one. I get just the pump not the tank. You'll need the puller for the pulley which you'll need no matter what. Pumps are easy to swap out. I've only had one go bad of the many I've done over the years and it was right away. You could go with online but having a store to run to for a quick swap is faster. Look up parts for a 84 k5 blazer diesel and you'll find one.
Sent from my SM-S906U using Tapatalk
Barrman
1,767
Giddings, Texas
I have the same experience as the post above.
The steering box is best rebuilt or adjusted. If that isn’t possible, look for companies that do the boxes for off road applications and contact them. I would not go with a parts store box. Junkyard or parts truck would probably be better results.
