Need help identifying a few MRAP parts.
187
Youngstown, OH
Need help identifying an air brake cylinder on a BAE Caiman MTV MRAP. No part numbers visible...one went bad. Brakes locked up. Any ideas appreciated. Right side, rear wheels.
Also some "things" mounted next to the seats in the rear compartment.
Tnrobocop
Mobile, Alabama
Not sure on the brakes as we have a Maxxpro, but the "things" according to our manual I believe are stretcher mounts for casevac. We took ours out since they got in the way of our plans for the vehicle and we are installing a bench/stage compartment on one side which can double as a stretcher mount.
NDT
7,436
Camp Wood/LC, TX
If you figure out the brake locking issue please post the solution. The Arvin Meritor axles were a "one of" and no parts seem to be available. I have been asked by several agencies to assist with the brake locking issue on the II's and came up empty. I get the impression the II's had engineering bugs that were not solved.
Oklahomadeputy
Mustang,Oklahoma
Thank you on the brake chamber part # , I needed that. The above mounts next to seat are a stretcher mount setup.
I took them out of ours and installed more suspension seats. You can do bench seating also. Look up MRAP Texas and you'll see a company whom did a sheriff MRAP in their area. I had side running boards built for ours so our team can ride on the side.
