Need help on a fuse that keeps blowing.
ssgtwright-usmc
Hawaii
I have one fuse that keeps blowing and I dont know what else that fuse feeds.
I know its a fuse that handles the fuel guage. I dont know if the blackout lights also use this fuse.
I can fill it up with gas and 20 minutes later it shows empty, blown fuse.
I have to replace that fuse every 2-3 days now.
Any suggestions at what other items I sould look at as in a short or ground.
Its tight at the fuel sensor/float.
SmokeyDod
Easley, SC
It has to be a "short" somewhere along that wire. I would start at the fuel tank (since you indicate that it is tight at the "float" I assume you lower tank & remove the unit from tank). Just follow the wire all way back to where it goes into your fuse block. The wire could have scraped place (naked wire) and as it shakes and moves while driving it could be hitting the naked area. Check closely at point where wire comes from fuel tank and goes thru hole in frame of truck.
ssgtwright-usmc
Hawaii
Will do, I replaced the sending unit last year and havent drove it till now. First time driving(myself) in a year. Had a MC accident at the beginning of year and now I am more like myself again then I was a few months ago.
I will never ride a bike again.
1,172
I would guess your problem, is NOT on the sending unit side of the gauge, since the sending unit simply varies the resistance to ground( a dead short to ground at the sending unit should put the needle to empty).
Your problem should be on the power to the gauge end(make sense?).
Warthog
229
OKC, OK
Looking at the electrical diagram from the TM 9-2320-289-20 Appendix F, Figure F-4.
The wire number from the fuel sender is Pink 30A. Following the wire, it goes thru a connection on Figure F-3 and reverts back to Figure F-4. The pink wire runs to Pin 18 on the instument cluster. Pin 18 on instrument cluster runs to the fuel gauge. The power for the fuel guage comes from pin #5. It is a black wire. It feeds other items also. I have not traced it down and it is not in the diagram.
Can you tell us which fuse blows? Wher is it located on the fuse block? Is it fuse #15
1,172
What main post? Can you give us a link? Do you have a thread already going about this problem?(why this post?)
Warthog
229
OKC, OK
The fuse you are talking about is shown as a 5amp Courtesy Lamp on all of the TM diagrams. Possibly the picture of on page 2 is incorrect or the manual is incorrect.
The diagram shows the fuse feeding the headlight switch for the dome light. Check you dome light wires.
Can you tell us what type of CUCV you have so we can troubleshoot the diagrams? I enjoy connecting the dots........LOL. Also reverify that it is the fuse that is the forth row from the bottom and the second fuse from the left.
