Need help to identify this tool.
GIBill
Philadelphia, PA
Hello all,
I hope you are doing well.
Could you me identify this socket-wrench?
NSN 5120-00-795-0404
PN 7950404
Thank you in advance.
Best regards,
Bill
frank8003
4,981
Ft. Lauderdale, Florida
I figure
bein Phile and all
you already did this
NATIONAL ITEM IDENTIFICATION NUMBER (NIIN) 007950404
NSN DESCRIPTION SOCKET,WRENCH,FACE SPANNER
FEDERAL SUPPLY CLASS (FSC) 5120 - Hand Tools, Nonedged, Nonpowered
CODIFICATION COUNTRY United States
ITEM NAME CODE (INC) 03543
5120-00-795-04045120007950404Socket, Wrench, Face Spanner03543
National Stock Number:
5120-00-795-0404
Federal Supply Class:
5120
National Item Identification Number:
007950404
Description:
Detail:
AN ITEM DESIGNED TO BE DRIVEN BY AN EXTERNAL OR INTERNAL DRIVE. IT HAS A FACE TYPE SPANNER END.
Manufacturer Information:
795040419207U S ARMY TANK AUTOMOTIVE COMMAND AMSTA-IM-MM
Techincal Specification:
DRIVE END SHAPESQUARE SINGLE END INTERNAL
DRIVE SURFACE SIZE0.500 INCHES NOMINAL SINGLE END
ANGLE BETWEEN LUGS90.0 DEGREES NOMINAL
OPENING DIAMETER6.000 INCHES NOMINAL
OUTSIDE DIAMETER7.000 INCHES NOMINAL
OVERALL LENGTH1.000 INCHES NOMINAL
LUG LENGTH0.500 INCHES NOMINAL
LUG WIDTH0.781 INCHES NOMINAL
MATERIALIRON OVERALL
STYLE DESIGNATORLUG
[h=2]5120-00-795-0404 Features[/h]
MRCParameterCharacteristics
ABHPOverall Length1.000 inches nominal
ABKVOutside Diameter7.000 inches nominal
AGAVEND Item Identification2320-00-835-8464 truck cargo
AGNJOpening Diameter6.000 inches nominal
AHMMLUG Width0.781 inches nominal
AJAQLUG Length0.500 inches nominal
ATNCDrive Surface Size0.500 inches nominal single end
CTCTDrive END ShapeSquare single end internal
CTLNAngle Between Lugs90.0 degrees nominal
MATTMaterialIron overall
STYLStyle DesignatorLUG
CARNAC
The Envelope Please.
619
Corpus Christi, TX
Yes, you are correct. This is one of the specialty tools for the M35A2 that nobody uses cause the just figure out some other tool to use that is more handy than finding this one that was packed away in some tool cabinet somewhere. PM sent.
F18hornetM
10
Ocean City, Md
Well you identified it but didn't tell him what its for. There are tons of spanner wrenches made for all kinds of custom applications. Thanks Jeepsinker and Carnac for answering his question and my curious mind. Would be cool especially if need to turn the crank in the opposite direction of the bolt instead of going around again and again.
