SasquatchSanta
- 18
- 0
- Northern Minnesota
Hopefully someone can help me understand an oil analysis report I received today.
I decided to get the analysis mainly because of curiosity. My truck runs fine, has good oil pressure, amble power and doesn't seem to smoke very much once warmed up.
I was curious to see what impact the Minnesota winter weatherr heating problem I was having before I removed the water pump fan and installed the electric fan might be having on the oil. Before I installed the electric fan the truck spent an appreciable amount of time idling at between 100 and 120 degrees and sometimes running down the road at not much over 140 degrees. Since the block wasn't heating up to anything close to normal operating temperatures I was concerned about what it might be happening inside the engine.
Here is the lab report:
Engine: LDT-465
OIL: Shell Rotella T
Miles/Months: 2,000 miles - 18 Months (2 winters - 1 without the electric fan)
Viscosity @ 100 degrees C (cSt): 14.8 (A)
(Numbers Signify Parts Per Million)
Silicon: 17 PPM (A)
Iron: 98 PPM (A)
Chromium: 10 PPM (A)
Aluminum: 14 PPM (B)
Copper: 12 PPM (A)
Lead: 14 PPM (A)
Tin: 0 PPM (A)
Nickel: 1 PPM (A)
Silver: 0 PPM (A)
The (A) Stands for Normal --- No Action Required
(B) Stands for Moderate --- Requires Monitoring (See Aluminum)
There is also a (C) which stands for: High --- Action Required
(D) Severe --- Immediate Action
(X) Pending Failure
Accordng to the the labs A thru X table the only thing that was out of whack was the aluminum.
The Labs comments were: "Suspect moderate cylinder wear"
I don't understand why they singled out aluminum @ 14 when they didn't iron @ 98.
I can't help but wonder if this doesn't have to do with dry starts and cold weather.
Anyway --- as good as the engine runs I don't think it is anything to be concerned about.
Any insight would be appreciated.
Engine: LDT-465
Silicon: 17 PPM (A)
Iron: 98 PPM (A)
Copper: 12 PPM (A)
Lead: 14 PPM (A)
Tin: 0 PPM (A)
Nickel: 1 PPM (A)
Silver: 0 PPM (A)
(X) Pending Failure
