M35fan
- 3,986
- 113
- Arab, Alabama
Hey yall. I need some info and advice. My Deuce shows symptoms of a bad air pack. I have the "long" pack. It won't build air pressure past 60 psi at idle. The brakes seem to be working fine and if I keep the rpms up, it will hold 120 with no problem. I hooked up my compressor through the emergency side glad hand and found air rushing out into the slobber tube from the vent line. Other posts I've read suggest that the air pack needs a rebuild. Does this sound correct?
Assuming that my pack is rebuildable, I plan to purchase a kit from Big Mike's and tackle it. Where in the TMs can I find information about rebuilding, and parts diagrams?
Any advice given will be greatly appreciated.
