need help with mep-003
drjconley
merced, ca
I just bought a mep-003 and I need to read over the tech manual. Does anyone know what TMs cover this generator. I put diesel in it, but the three filter canesters dont have any filters in them what filters should I buy. Is there any reason the fuel would up the first canester, but not the second or third. It turns over just fine and looks clean. Thanks ahead for any help, it is appreciated.
Jim
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
I have no idea what the third TM Nonotagain posted is for, but the other two are definitely the ones you want. The parts TM for the MEP-003a is TM 5-6115-585-24P.
The filters you need are a WIX 33113 filter for the fuel filters, they even come with the correct o-ring gasket to seal the bowl.
The oil filter is the WIX 51004, and you will need to buy a separate o-ring with that one as the one supplied is not correct. The o-ring is WIX 15108
atankersdad
15
Glen Arm Maryland
Please check to ensure you have an air filter. I have got 6 of the 003's and 5 came without the air filters. Also make sure you have an oil filter in that canister. In short, before you turn the knob, make sure you read the TM , make sure the fittings are tight and all the filters are in place and NEW!!! Do not trust them (GL) for having any filter inside a canister without checking or trusting that it is usable. These are great units if ran properly, and running them properly at this time is your job, not the PVT that had it before you... If you have a question about one of these you can pm me or Speddmon for help. He knows more than I do but i do not mind breaking out the TM and reading...
Speddmon
Cambridge, Ohio
Thanks for the vote of confidence atankersdad, I don't know that I know more than anybody on this site, but I do like to tinker with them, and playing with electrons is my job.
Like he said, Send a PM if needed, or post your question, I'll try my best to help anybody out.
atankersdad
15
Glen Arm Maryland
We are all in this together!!!
