Need help with my exhaust cross heads!
US6x4
2,188
Wenatchee, WA
I'm trying to swap in my Jacobs exhaust cross heads but they interfere with the rocker box no matter which way I twist them. Should I force them on with a hammer or do the rocker boxes have to come off? I don't have rocker box gaskets.
@WillWagner
US6x4
2,188
Wenatchee, WA
I do have a set of 013294 jake gaskets which may be the same as rocker box gaskets so I could do the cross head swap, rocker adjuster swap and stud swap while I wait for another set of gaskets...
WillWagner
2,608
Monrovia, Ca.
You need to take the boxes off to install the dual piston cross heads.
simp5782
Feo, Fuerte y Formal
9,339
Mason, TN
Any ideas on the part number for the rocker box gasket?
For the NTC400 they are # 3017750. Which is what you should be using. Heads between small and big cam are the same. Some rocker box differences but not much.
US6x4
2,188
Wenatchee, WA
Bingo! Thanks for that number. The last digit make a big difference in searches...20200404_180839.jpg
