mynewtoy
- 2
- 8
- West Pittson Pa.
I just pulled the NP208 out of my 1985 M1028 to swap in a NP205 W/PTO before I started this swap I called the local dealer I deal with to make sure this was a direct swap the doner vechicle was also an 1985 1 ton non military Chevy 350[Gas] with a Turbo 400 I was very clear about the question is the output shaft on the tranny the same between the NP208 & the NP205. He looked it up and said there was no difference well now that it's apart it seems to me that he was wrong. My shaft looks to be to short. Has anyone ever done this swap? If so is there an easy solution to my problem? The output shaft on my tranny measrues 2.5" from the 6 bolt flange to the end of the output shaft. It looks like it needs to be 4.5" this truck only has 6400 miles on it I really don't want to pull the tranny apart if I don't have to. Any help is graetly appreciated.
Thanks in advance
Thanks in advance
