Need info, can't find it.
I know this has all been covered before, some of it numerous times, but please bear with me.
1. What glowplugs for a manual conversion, no controller card or anything except a switch, a relay, and the plugs? AC60's or Wellman 070's?
2. What size freeze plug heater?
3. Where to find a gas fueled block heater?
4. Anyone have list of the filter numbers and fluid capacities?
5. Do the M1009's have limited slip in the front and rear, or rear only?
HeadWizard
Chantilly, VA
In the resources tab:
LO 9-2320-289-12 is the Lubrication Order
TM 9-2320-289-10 is the Operator's Manual
TM 9-2320-289-20 is the Unit Maintenance Manual
TM 9-2320-289-20P is the Unit Parts Manual
TM 9-2320-289-34 is the Intermediate Maintenance Manual
TM 9-2320-289-34P is the Intermediate Parts Manual
Download them all from the Resources tab at the top of the page. Towards the back of the -20 is where the wiring diagrams are located (just in case you ever need them)
M1009 has Limited slip in the rear only.
JC
Crofton, MD
I've used AC60's and Wellman 70's in my 24V M1009. Both worked fine but I noticed it took the wait light longer to go out with the 60's. The 60's have a wider end than the 70's and will not work with the stock clip on the end of the glow plug wires. If you use the 60's you'll either need to swap out the glow plug wire connectors or you can file down the 60's to fit into connector. I would just use the 70's.
