Need Oil Filter Gasket Part Numbers for NHC-250
bevanet
Arizona
I didn't want to start a thread for this, but I really searched pretty hard and couldn't find this info. I am about to change oil on an M813 with the NHC-250 engine. I have the filter and oil, but I haven't been able to find the gaskets that go on the filter housing. If anyone knows which stores carry these and what the part numbers are I'm sure it would be helpful to many. I agree that a spin on fliter is a better solution, but the truck gets very little use. I hate to spend extra $$ for a spin on when it won't save very much time over the next several years. Information on multiple stores would be helpful since we live in various states. Thanks!
1,172
Did you try google searching the NSNs?
bevanet
Arizona
I ordered these from Checker / O'reilly. They are a wix 15271. I hope to try them out in a few weeks. I'll post if they work or not.
bevanet
Arizona
I got the oil change this weekend. The wix 15271 fit perfectly. I didn't replace the washer on the end of the canister bolt, but it isn't leaking. I did this late in the evening, so it was getting dark out. After I loosened the canister and let the oil drain over the front diff, I noticed that the canister has a plug that must be used to drain the oil before taking it off. I'll try that on my other truck to make a little less mess hopfully.
Floridianson
2,487
Interlachen Fl.
I have used the same rubber over at least once with no leakage. The way the canaster and rubber work together with a slight beval just clean the rubber and can well.
