Need part numbers
Warthog
242
OKC, OK
The switch on the drivers side rear, top of head is the glowplug temp sensor, not the high idle.
Where then is the high idle sensor? Mine is not working, connections at the control is is fine, both green wires connected. Engine was out for a head swap, and am now having issues. No high idle, hard to start after setting a while, and they put in a 12v gear reduction starter. My 24v solenoid has a broken connection I need to redo.
I am going to check the tightness of the pump connections and fix the solenoid, but am flumuxed on the high idle.
I also have a 2 wire connector on the passenger side, a green and a tan wire, just hanging...
Warthog
242
OKC, OK
Its on the passenger rear.
Item #2 on the diagram from TM 9-2320-289-20P
