Need sectional Antenna for MX 6707 base
gasser
Ocean Springs, MS
Mark, what antennas do fit for the 6707 then? Are the AS-1730/AT-1095 set the only ones that fit?
I guess I will start seaching eBay and the vendors ...
Thanks.
emmado22
164
Mid Hudson Valley NY
I'd have to check the TM for the #'s, but you want the 2 section antenna. NOT the SINCGARS one, but the earlier one.. I'll put the #'s up later when I get home...
ONTOS66
Franklin, NJ
Antenna AS-1729/VRC consists of:
Matching Unit-Base, MX-6707/VRC
Lower Antenna Element, AS-1730/VRC
Upper Antenna Element, AS-1095/VRC
Per TM 11-5820-401-10-1
Fair Radio has the upper element for about $18. Murphy has the whole antenna with base. I haven't seen the lower element advertised recently.
Good luck.
