Need small oil filter gasket
englishmauser
Lancaster, WI
I bought two Carquest 85133 oil filters. They came with two large gaskets and no small gasket. Where do I get the small gasket and are the two large ones correct for my M35a2? I just got truck a few weeks ago and this is my first oil change. Thanks in advance.
deuceman51
10
Scotland South Dakota
My filter kits come with the correct gaskets included. I'm not sure about the carquest filters though. If the existing gasket is not cracked, hard, or deeply imprinted from the cannister you should be alright. I reuse some gaskets if they look good. I usually flip them over so the side that usually has a groove cut into it from the cannister is against the filter base. Has worked very well for me over the years. Of course using a new gasket is always best.
