CurbRash
- 1
- 0
- Dripping Springs, TX (Austin area)
I've searched the forums, read many posts, and now I'm really confused - ![Confused :???: :???:](https://www.steelsoldiers.com/images/smilies/icon_confused.gif)
What I'm looking for is the physical location of the following components (assuming I have them right):
Glow Plugs - no brainer; under the injectors in the manifold
Glow Plug solenoid
Glow Plug controller
Glow Plug controller card
So here's what I have:
1984 M1009 CUCV, everything I assume is stock.
Problem I'm having:
Engine won't start; turns over but no fire. I replaced the stock Wellman glow plugs with the AC Delco's G60 (G60 Delco's have a wider connection on the tip BTW, had to modify).
Insert key, turn on ignition, "Wait Light" turns on, after a few seconds I hear a "Klak", about 5-10 seconds later the Wait light turns off, turn key, no fire after several attempts. Wait Light comes on again, same process, as before. It will fire on some occasions with a bunch of gray smoke coming from exhaust and It will fire if its warm enough outside or the engine has some heat. Seems like the Glow Plugs are NOT getting any current.
I'm thinking its the solenoid\controller, or controller card, but I'm not sure where those parts are physically located in the vehicle. Thought about giving the enhanced replacement hillbilly controller card a try, but I'm not 100% sure where its located.
Any help would be appreciated, TIA!
Glow Plug solenoid
Problem I'm having:
