I just got offered 250 gallons of WMO for free from a man I met at a barbeque who thought the Deuce was pretty savage. As it turns out its mostly out of bulldozers and such, but some of it is kind of old. He told me if I dont make a mess Im welcome to it!
Now, Im trying to make sure I do things in a cost effective way, but I have an idea of what I want to see. I would love suggestions on how to make it happen though.
After some reading I have seen people using sock filters, like you would use for a pool filter. I wish I had bookmarked that post, but I remember the person posting that he had found them as small as 1 micron, and he had said they were less than a dollar each, which I like the sound of! I am picturing the sock in clear canister assembly thing....
I also have read a few people mention a Napa filter that was like, 15 microns and had a water separator. If someone has the part number for this or some more information that would be useful before I start spending money, please and thank you!
I also have a mesh sock that was designed to fit over some perforated pipe my folks used for their back yard project, they had 150 feet of it left over and it was given to me. Its not a tight enough weave to use as the only filter, but it gets things like pine needles and big crap out of the way so my chosen filter lasts longer.
This is what I have pictured: I will most likely have to pump the oil from his drum to my own, and I will use 3 feet of the mesh sock thing over the mouth of my barrel, this will allow to pump it quickly while still getting large chunks out.
When I get home, I do not have a forklift to remove the barrels, so I will have to pump it from the truck to an empty barrel. When I do this I would like to filter it through a 20 micron sock, and the napa water separating filter before it is dumped into the barrel.
When I go to pump it back into the truck's tank down the road, I would like to pump it through the napa water separator again, and a 1 micron sock.
Some explanations about my trains of thought:
-The Napa filter that I am picturing is a spin on filter with the moisture separator on the bottom. This filter would be more expensive to change than the socks, all I really would need it for is separating the water.
-I want to filter to 1 micron if I can. Some of you say this is overkill. You may be right. I want to anyway![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Some of the things I am not sure about:
-I looked at the filter my parents use when they vacuum their pool, its a sock filter in a canister, but the hose fittings are very large, and I am not sure how I would transition from the Napa filter to the canister with the sock...
-Where do you buy the sock filters? Will my local pool supply store have them?
-What type of pump do most of you use? I have a setup that uses air pressure, but I know that is not the safest way to do it, and the potential for a mess is extreme.
-How horrible is a hand pump?
-Do any of you test the viscosity of your alternative fuels? (To make sure it isnt too thick) If so, How?
-Do you thin with Gasoline or Kerosine, which one, and why for?
Im going to harbor frieght, napa, and the pool suply store tomorrow. I hope to get more information and some prices, but I dont want to spend any money till I have aquired the oil. Just looking for suggestions and input, ya'll have been there and broken that already.
Also, please excuse any extremely stupid thoughts or questions. I am a power n00b when it comes to alt fuels.
