rickdavis81
- 84
- 28
- Rich Hill, MO
When I bought my truck the owner said he replaced the ip with a rebuilt unit because the original was leaking fuel. After replacement he could barely get it to run if giving it a hit of ether. He thought it was getting air in the lines. I checked the timing, #1 cylinder valves are both loose and crank pulley indexed at proper mark indicating tdc and ip mark lined up with the pointer. Old diesel had a stale smell so I drained the tank and refilled with fresh and changed the filters. In tank pump is operational. The fuel shut off only returns to the 6 o clock position instead of the 7 o clock. Possibly my problem? Truck will fire with a shot of ether and will stay running but won't idle and is slow to rev, no smoke from the exhaust. Won't refire if allowed to die without a small shot of ether, which I really don't like using. Also the small plastic line running from injector to injector, which I assume is for the flame heater. Where it tees off to go to the flame heater I assume, it's just cut off and open. Could that be inducing a lot of air?
