Need to find M35a2 felt window channel glides the for both driver and passenger door
Haveittoplease
Wyoming, Mich.
Just what my title says. The vertical felt channels 2 for each window, driver and passenger doors for an 1971 M35a2. According to the T.M. diagram is it called item no#3 non-metallic channel part 7373300? spent an hour on the site no luck. I did look first now I ask last. If anyone has 2 driverside and pass. side. how much or where to look?..help
Warthog
232
OKC, OK
There is felt in the window channel? The Tech Manual doesn't show any.
gungearz
northwestern indiana
There is felt in the window channel? The Tech Manual doen't show any.
There is felt in the window channels. The reason why they are not in the TM's is because they are part of the channel. Every door window needs them to stop the glass from bouncing in the channel. From breaking. From MV's, hotrods and new cars. My deuce window felts are still there but worn pretty good. I might do mine also.
Haveittoplease
Wyoming, Mich.
Gungearz, check out TM9-2320-361-24p figure 107. Door and window assembly pc.no. 3 "non-metallic channel", per part no. 7373300. That's what makes me think there's a separate piece - the felt channel.
Tinwoodsman
76
Comfort, Texas
Integrated Parts Systems (IPS) They have them in the Military Parts/Body section. There is a long one and short one. $27 and $26 ea. You will need some small rivets to fasten the front ones at the top. Makes a world of difference.
