Need to move a M35a2 from Somerset to Pittsburgh 100miles
DB556
129
Ambridge, Pa
Well I just won a M35a2 and will need to move it in Southwest Pennsylvania from Windber down near Somerset (zip 15936) to Ambridge north of Pittsburgh (Zip 15003)
If anybody is available please PM me a quote.
Scar59
41
Mt. Eden, KY
Is it drivable? Not up on PA zip codes; what is the distance? They tow real easy with another big truck.
DB556
129
Ambridge, Pa
They say it must be hauled and they say it has a fuel issue, but from talking with the mechanic I think its the lift pump fuse. The distance is 100.1 miles.
dmetalmiki
2,027
London England
If you have not driven one much before, Transport. And in any case if you do drive it, Enjoy the 'Adventure' And post up pictures when safely home.
Drive 'Nicely'...take in the fun and experience of the journey.
2250 RPM would be a steady (and) Reliable cruise.
Take tools, food? drinks, But stop to indulge in any case.
BE SAFE, >Take care---arrive alive<
edit.
Nearly forgot, A very welcome to the site, hobby, friendships and events to come.
DB556
129
Ambridge, Pa
I've driven one before, my friend had one that we used to move equipment. His was a C turbo I'm hoping this is a D turbo, it drove me nuts when I was driving it.
The mechanic said it might be a easy fix probably lift pump, if it isn't it would be good to get a quote to haul it.
Scar59
41
Mt. Eden, KY
The pump in the tank is an easy fix. There is no true "fuse" for the pump. A wrecker service may be the way to go. I had one transported 50 miles on a RGN, $250. Truck ran, just not brakes. Maybe find a member here with a tow bar. Nice afternoon project.
fasttruck
633
Mesa, AZ
They must be charging you $5.00/mile BOTH ways. The loaded move should pay $4-500.00 for 100 miles. Need to tell the carrier if this has to be loaded from the ground or are there loading docks at both ends of the trip. Does the truck run well enough to drive on the trailer, because if they have to winch it on they are going to charge you for that.
fasttruck
633
Mesa, AZ
Consider finding an excavator or someone with a dump truck with a tag along trailer long enough for your truck to se if you can get a better rate.
