NEED TWO (2) DIGITAL LIGHT SWITCHES FOR HUMVEEs ------------
1,808
RE: NEED TWO (2) DIGITAL LIGHT SWITCHES FOR HUMVEEs --------
Front Line Military Vehicles just listed them on their site. Google for the info.
FMJ
37
Las Cruces, NM
Check epay, Beltfed34 has them for 50.00 I think.
cranetruck
75
Meadows of Dan, Virginia
Images54 do you still have the 3-lever switches? I may be interested in at least one of them if they work....
ida34
33
Dexter, MI
Re: RE: NEED TWO (2) DIGITAL LIGHT SWITCHES FOR HUMVEEs ----
rmgill said:
Are they technically digital or just electronic?
You do use your digits to turn it on and off. I guess both the electronic and lever switches are both digital then.
Watch out when you buy them. There are small surface mount relays that fry on early ones. I fixed the one that an ebayer dumped on me. Be careful. I bet front line would at least back them as not being doa.
bulldog_mack13
3/3 ACR
2,968
34
Colo Springs, CO
RE: Re: RE: NEED TWO (2) DIGITAL LIGHT SWITCHES FOR HUMVEEs
it said they work and i installed one in my old M37 and it worked great! but thanks ofr the warning.
- how do you fix a broken one?
ida34
33
Dexter, MI
Remove and replace the relays inside. They are surface mount so it takes an experienced hand. I had my uncle do it. He used to have an electronics assembly business. The relays are not cheap. I think I had about $30 or so into the relays. One was obviously fried but I replaced all four while I was at it.
ARMYMAN30YearsPlus
Parkville, MD
I really like them too and have one in the duece. I think the old ones had most issues with not being grounded properly especially in a HMMWV. Mine is second generation I am 99.9% sure but has worked fine in the truck and to me is easer for me to work getting a bit older.
m-35tom
222
eldersburg maryland
a few years ago you could buy them direct from stewart & stevenson for about $120. the 'relays' are solid state switches and are cheap although they add up. if anyone needs one repaired, contact me.
saddamsnightmare
80
Abilene, Texas
July 31st, 2008.
AND BE SURE TO GROUND IT!!!! Particularly as the HMMWV uses composites in its construction, be sure to connect the green ground wire on the TACOM switch to some metal part of the frame or cab that has a ground strap attached before you install the switch.....that way there is no static charge on the switch housing to take out the relays!!!! After the ground wire's hooked up you can install the main harness and screw the switch into the dashboard. There should be not problems thereafter, provided you MAINTAIN the ground, and you'll have many good miles of operation.... :beer:
Sincerely,
Kyle F. McGrogan
1971 Kaiser Jeep M35A2 Wo/W "Saddam's Nightmare" Desert Storm and Vietnam Veteran truck...
1968 Johnson Corp M105A2 Cargo Trailer
1967 Hercules MEP023A gas Gen-set APU
1963 Swiss Army Cargo Unimog, S404.114 MB
hummer4x4guy
Lansing, Mi
I am on my 3rd of these light switches also and finally this one seems to last. I always hooked up the ground wire first disconnected the batteries then screwed the new light controler in but the first 2 went to pot within months.... But the ease of operation with one hand and at night was worth the cost IMO.
Joel
cranetruck
75
hummer4x4guy said:
I am on my 3rd of these light switches also and finally this one seems to last......
During the starting and shutting down of an engine, electrical spikes are sometimes generated and electronics are supposed to be off, as is generally known. An electronic switch, which must be on at all times to be turned on in the first place should really be protected by a mechanical toggle switch or similar.
If, for some reason I was stuck with one of the new light switches, I would add a switch (or electromechanical relay) in the circuit to make sure it was off when the engine was started at least....
