Need voltage regulator for M35 alternator
Gun Chuck
Des Moines/Iowa
I had an alternator rebuilt from a 1971 M35A2 deuce. It is labled Southern Automotive Wholesalers Inc Pontiac Michigan Code Ident 1Y875. It needs a replacement 24 V voltage regulator. The regulator is part of the back plate or cover of the alternator.
Anyone with any leads or one they want to sell or trade ?
deuce808
Alpharetta Ga
i am curious.. isnt a voltage regulator either working or not, theres no in between right??? my volt meter was going up and down tonite and thinking a voltage regulator may be a problem,, the volts are in the yellow with lights on and in the green with everything off and engine running... what can you advise
1,177
Use a volt meter at the batteries, you may just have a bad ground on the dash panel screws or the gauge mount. measure voltage before starting, then start it and measure voltage again. It should be higher when running. If it is not or it is "bouncing" then you need to find the problem. I would bet your dash panel is not grounding well or your gauge is going bad.
Speddmon
Blind squirrel rehabiltator
Cambridge, Ohio
Gun Chuck,
If you know for sure it's the regulator, call Southern Automotive...google them, they are still in business and still supplying the govt.
deuce808
Alpharetta Ga
i have determined that I have a generator.. its seems to be putting out just under28v like 27.7V..... as i turn on the accessories( lights on high beam, heater, flashers ect) the voltage goes down to upper 26v area... is this normal... do i need to up the voltage from the generator.. and the batteries are JUST covered by acid, should i add distilled water to a specific level.... does this 2v fluctuaton indicate anything i should address now....
