- 3,532
- 3,433
- 113
- Brooklyn, NY
Starting to dissect and rebuild my HMMWV PCB. I want to find male and female plugs to cut into and attach waterproof to the PCB box. I want remote switches and pushbuttons that will support 24V and 20amp, with 8 guage wire. I want to place watertight plugs on the side of the PCB box, and run low current 24V wires to the box via a plug, with push button control for glowplugs and toggle switch or similar control to activate the relay via the low amperage "on" wire.
I need diodes that will support 24V and 70amp.
I'm trying to bypass low current "on" wire to relay with a diode and switch, and connect the starter to solenoid wire with a diode and switch. I also will create a separate relay to power glow plugs through the PCB with diode and switch and relay.
What plugs male and female should I buy? Where should I source the plugs to attach to the side of the PCB box in a waterproof manner?
What remote switches and what pushbuttons should I buy and where to source. I want low amperage to the switches but still 8 guage should fit the bill.
Diodes are overkill, but what and where to source?
Finally, what relay to use and where to source.
Later on I will want to buy 24Volt circuit breakers of varying amperages. Where to source?
Thanks In Advance!
T
My PCB thread for HMMWV is linked below:
https://www.steelsoldiers.com/showt...PCB-I-am-aware-some-HMMWV-owners-have-done-it
Thanks In Advance!
T
