Nevermind.... Got it. M998 Fuses / circuit breaker
Thumper580
210
Virginia
I out on a new aftermarket horn on my M998. It honk OK, then started it and went fir a ride. No Headlights or horn...
Is the attached picture a FUSE or circuit breaker. If not where are they. Thanks.
Milcommoguy
2,255
Rosamond, CA
OK... ?? Got a "new aftermarket horn on my M998. It honk OK, then started it and went fir a ride." What kind of mileage are you getting on the horn ride?
Not seeing the picture.
Two circuits breakers behind the dash and a little to the right. See the TM's to be sure.
Ear plugs require, CAMO
Thumper580
210
Virginia
They were behind the instrument cluster on the left side. Apparently they are self resetting. After I fought to get one unbolted I guess enough time had passed.... Started the engine and the lights were back on!!. Mess with the horn again tomorrow.
papakb
1,185
San Jose, Ca
Your correct about the circuit breakers being self resetting but the headlights don't get their power through them. You must have jiggled something when you were in there.
TM 9 2320-280-20-3 has the schematics in the back. Chances are if you have a 998 you also have a 60 amp alternator so the first schematic you come to is the one you want to use.
