I picked this up last week from the texas forest service in lufkin. loaded the truck with the wheels locked. The lock cylinder was broke, ignition rod was not attached. I replaced the lock cylinder and used a vice grip to grab the ignition rod . I installed a couple of batterties, pushed the rod to the run position and heard the glow plug relay thump. wow, ive got a good controller card. engine fired up and is running good. alternators are charging. transmission engaged and pulled itself off the trailer. Brakes worked. There's a water leak from the intake somewhere that i will get to later.
