New 6.5 for cucv, sort of.......
EnteJager
NJ
I got to preview this one a couple of weeks ago and won it last week.
The engine looked like it was taken out with hardly any milage on it. The whole engine has that new engine look, paper stickers intact and legible, no tool marks on any bolts, clean inside the hoses. Even the headers look like they never saw much heat. Spotless. We'll see how it checks out when I get her home.
NSN puts it at a 1996. :-D
jwaller
19
Columbia, SC
that is an unusual piece. 6.5 with serpentine and hmmwv intake and headers. thats exactly what I want for my truck. it was prob removed after such a short time bc it had no oil pressure or had a bad noise.
hook up the starter and see if you can get oil press before you install it. might save you some headaches.
dilvoy
25
San Francisco, Ca.
You can pull the glow plugs and look for glycol. It may have overheated and blown a head gasket, so I'd do a compression check and look for glycol in the oil too.
1,807
Had the same thing. Was a 6.5 center mount turbo motor. I ended up giving it to Devilman and after install he found that it needed a piston and precup in one cylinder. Looked like they installed it, fired it and pulled it out. Perhaps something was left in the cylinder!
