New Axles....
FMJ
37
Las Cruces, NM
Motor RPM seems to run just a bit higher at 70 mph than it did before with the 3.08's and the 31" tires....
I need to find that rpm calculator again....
2660ish seems about right....
up from 2338 with the 3.08's with 31 inch tires...
1,806
It's pretty easy and you can do two at once for comparison. Select the tranny (400 Turbo) Transfer (NP208) Tires and gears and it does the rest. Even calculates the tire height of metric tires. Play with it for a few and you can really speed through it. I use it alot.
FMJ
37
Las Cruces, NM
I'm sorry, sarcasm doesn't translate well here.....
4" blocks rear, plus 1 leaf, positive arch springs, plus a leaf front.....:p
