- 51
- 0
- 8
- Grangeville, Idaho
New C.E. Niehoff dual voltage 12v-24v 200 Amp bi-directional alternator. It is rated for 200 amps on both the 24 volt side and 12 volt side. Some call these alternators 12/24 or others refer to it as 28/14 which are one and the same. I have the spec sheet if you would like to see it. Application 2½ ton M-1078 FMTV. It may work on a M35 2½ ton or M939 series 5 ton but it may take some adaptation creativity.
$1,200. FOB: Grangeville, Idaho.
Shipping weight 85 lbs. UPS Ground shipping quotes on request.
