New dash panel :-)
theeDIZ
Annapolis MD
Are you planning on using backlit gauges? Also curious about the extra small gauge holes , are they for egt/boost ?
1,129
I love all the projects you do. I really liked the rebuild metal battery box you did. The hold downs looked great.
59apache
Chipmaker
1,299
29
Bavaria / Germany
thanks @ all! It was fun to mill 2 steelplates for pressing the bead and get these results. It's only 19 gauge (1mm steel) but my 10ton press is to small...
brianp454
11
Portland, OR
Wow Apache! You actually made a tool to make those gage panels! Brilliant! It looks like you’re doing the forming after the holes are cut, which allows you to make the panels with any hole configuration you please. Are you laser cutting or water-jetting the holes?
59apache
Chipmaker
1,299
29
Bavaria / Germany
Hallo Brian, sorry for the delay!
The plates are laser cutted before the bead was formed.
I don't have a laser, but with a .dxf .dwg file it is easy to order the plates.
Greetings Juergen
rustystud
2,945
Woodinville, Washington
Juergen, do you have any plans to sell these ? I for one would like to buy a couple ! It would be nice though if you could make them from a little thicker gauge metal. Just saying this could be a good little money maker for you.
yolner
68
Rockville, MD
Hello Rusty, i don't plan to sell these. Thicker material would require a larger press :)
Greetings Juergen
Could you upload the CAD files somewhere? Maybe someone in the US could make a few of these and sell them for those of us who want one. I definitely like the look with the big gauges on the left.
